Hi All - Hope someone has encountered this or can shed some light.
PC was running fine for months. Then out of the blue (no pun intended), left it on OBS w/ Premiere Pro, came back & series of reboots with “Preparing Automatic Repair”. Should note this is right after post. Able to get into the BIOS & set all to factory. Made three different bootable USB’s, BIOS detects and attempts to boot however they also get stuck in the “Preparing repair” crash loop.
what I’ve tried -
reboots, USB’s, reseat ram slot by slot, remove all HD and isolate USB media, replaced UPS power cable, checked all other cables and connectors.
System Specs
CPU - AMD 3800XT
MB - Aorus X570 Master
Ram - Corsair Vengeance 32K
GPU - 3090FE Nvlink
PSU - Thor 1200W
BIOS ver - F32 (downgraded from F33 as I thought that might be the culprit)
Again - Any info helps and is appreciated. Thank you.
Attached is the only blue screen I was able to get to.
edit: also cleared CMOS
https://linustechtips.com/topic/1330516-nothing-boots-preparing-auto-repair-loop/
