Budget (including currency): ~3000 Euros
Country: Portugal
Games, programs or workloads that it will be used for: No games. 5 trading platforms, multiple tabs in a browser, skype
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): buying asap, need ability to have at least 6 displays
Hello LTT community,
I've never built a pc before and wanted to upgrade my aging and very slow pc. Like mentioned above I don't need it for gaming but mostly for day trading with 6 displays. I used pcpartpicker to get started on a parts list. Seems like the parts are a bit cheaper in Germany. The below listed is 2330 Euros without shipping. I would appreciate any input you have! Thank you
https://linustechtips.com/topic/1330475-first-build-for-trading/
Just now, Downkey said:
Might as well get a prebuilt since the 5950x is signficiantly above msrp and the 3060 is 2-3 times the price it should be
