just built my friend a budget system, everything seems okay, but the cpu is idling at 52 c (according to the UEFI) i havnt isntalled an OS yet.
specs are
BitFenix Comrade Case Black
ASUS A55BM-A-USB3 Motherboard
Kingston SSDNow V300 120GB SSD
AMD A6 6400K 2-Core Processor
G.Skill Value F3-10600CL9D-4GBNS 4GB (2x2GB) DDR3
Corsair CX-430 V3 Power Supply
using stock amd cooler, i know intel chips dont usually idle that high, but i thought maybe the APU's run a hotter? im thinking maybe i didnt seat the cooler correctly?
PC: Corsair 900D | Corsair AX860 | Maxmius VI Hero | i7 4770k | Corsair H100i | 16GB Corsair Vengeance Pro 2133 | Sapphire Radeon 7950 | Samsung 840 Pro 256GB | Win7 X64
HTPC: Silverstone GD05 Black | Corsair VS350W | AMD A6 5400K | AsRock FM2A75-PRO4-M | Corsair Vengeance 2x4GB DDR3 1600 | Samsung 840 128GB | WD Black 4TBx2 | Leadtek Winfast DTV2000DS | LiteOn BD\DVD-RW Combo | WIN7 x64/XBMC
https://linustechtips.com/topic/133046-normal-idle-temps-for-amd-apu/
theres always issues with amd temp sensors so thats likely why
Specs
UEFI isn't "idle" so that's normal.
And as mentioned the temp sensors on APUs are pretty crap.
