when i plug my headphones in my computer and when i listened to music the left ear was normal but the left was very quiet then i tried pluging into my laptop and it worked fine. so i went back to my pc and i tried not pluging it in all the way and that worked but i dont want to keep doing that so i was like "maybe its just the aux jack" so i tried the one on theeother side of the pc and it does the same thing. i dont know if this has anything to do with this but my sister was trying to get obs working around when it  starte happening she might of change a setting but she says she diddent
also it happens with diffrent headphones too.
and i tried mono
https://linustechtips.com/topic/1330447-headphone-problems/
and i tried mono
i reposed in here becase this place is the place for trobleshooting
https://linustechtips.com/topic/1330447-headphone-problems/#findComment-14676026
Read before asking for help  |  How to respond to a no POST or no power up situation  |  Don't ask to ask, just ask  |  The XY Problem  | Don't just say "Hello" in chat  |  How do I ask a good question?
If my post helped, please give a 'reaction' using the heart 🤍 in the bottom right.
Make sure to quote posts or tag the person with @[username] so they know you responded to them!
F@H Contribution
BOINC Contribution
HeatWare
"The only difference between a problem and a solution is that people understand the solution."
"Give people permission to make mistakes and the obligation to learn from them."
“The capacity to learn is a gift; The ability to learn is a skill; The willingness to learn is a choice.” - Brian Herbert
"People will never truly understand something until it happens to them."
"I usually give people more chances than they deserve but once I'm done, I'm done."
CPU AMD Ryzen 7 3700X  |  Motherboard Gigabyte X570 Gaming X  |  RAM Corsair Vengeance LPX 2x8GB 3600MHz  |  GPU ZOTAC GAMING GeForce RTX 3070 Ti Trinity OC |  Case BitFenix Ghost  |  Storage HP EX920 1TB, Samsung 840 EVO 250GB, WD Black 8TB, Seagate Barracuda 4TB  |  PSU Seasonic Prime GX-750  |  Displays Lenovo ThinkVision P27q-20, Dell UP2716D  |  Cooling Noctua NH-D15  |  Operating System Windows 10 Home
https://linustechtips.com/topic/1330447-headphone-problems/#findComment-14677389
Difficult to say, it's one of those "unless it's happened to you" things the solution could be anything.
I would say start by uninstalling OBS completely since that's the likely culprit, or if you don't want to uninstall it just spend a lot of time messing with settings.
One random thought I just had..... there is a way to send your audio output through the network with some kind of banana program or something, I didn't pay attention when someone was talking about it but it sounded pretty cool, might make a post asking about virtual audio cables or search for it.  My point being that if you can send the audio to the laptop over the network and it still does it you know it's software related and not hardware.
Audio go Brrrrrr
https://linustechtips.com/topic/1330447-headphone-problems/#findComment-14678067
