Budget (including currency): about 1600-1700 Euro
Country: Austria
Games, programs or workloads that it will be used for: mostly battlefront 2 and preparing for the future(and some mining at the side, probably, less for profit tho)
Since GPU's are pretty much impossible to find for a normal price, I found two prebuilds that are i think are not too bad value.
(the website's are German, but ill list the important specs here)
I already have a 1440p Ultrawide.
1)
Price: 1599 Euro
Specs:
CPU: R7-3700x
GPU: RTX 3070
RAM: 2x 8GB UDIMM DDR4-3200
Storage: NVMe SSD 512GB
Link: Here
2)
Price: 1649 Euro
Specs:
CPU: i7-10700
GPU: RTX 3070
RAM: 2x 8GB DDR4
Storage: SSD 1024GB
Link: Here
Any advice would be appreciated.
https://linustechtips.com/topic/1330194-need-some-help-deciding-between-two-pcs/
Country: Austria
1)
Price: 1599 Euro
Specs:
CPU: R7-3700x
GPU: RTX 3070
Link: Here
2)
Price: 1649 Euro
Specs:
CPU: i7-10700
GPU: RTX 3070
RAM: 2x 8GB DDR4
Storage: SSD 1024GB
Link: Here
The 2) build is better.
It's not that much more powerful ,but considering the price difference it could be worth it if you are playing more CPU intensive.It depends how much you value those 100€.
https://youtu.be/5gsT2NBkXvg the benchmark I watched...
I didn't think the Intel would be better tbh, I was going off Passmark(https://www.cpubenchmark.net/).
Ill go with the second one in that case, thanks a lot 🙂
At one point  I thought passmark was a good source...
Oh well the 10700 is a bit better in both single core and multi core workloads which includes gaming and photo editing,video editing, you get the point....
Seeing as the only difference worth mentioning is the CPU I don't think this would be a hard choice.
