Webcam/ lighting help.
Go to solution Solved by Action_Johnson,
It's the webcam running Auto-Exposure. Does it have a manual exposure capability? If not, then you need to look into a different option, or a real camera to pipe in a feed.
I have a logitech streamcam as a webcam for my computer. I am trying to set it up to get the best quality I can out of it for work conferencing and maybe one day streaming. I believe I have my lights set the way I want but the camera is doing something that I need help figuring out. with my lights on the image seems really bright (colors are good) but if I put my hand up between me and the camera the brightness goes down (I want this image from it) can anyone tell me what may be causing the change in brightness on the camera from just my hand going up (hand is not blocking my face from the light source). Any insight or help is appreciated!
https://linustechtips.com/topic/1329839-webcam-lighting-help/
Work Rigs - 2015 15" MBP | 2019 15" MBP | 2021 16" M1 Max MBP | Lenovo ThinkPad T490 |
AMD Ryzen 9 5900X  |  MSI B550 Gaming Plus  |  64GB G.SKILL 3200 CL16 4x8GB |  AMD Reference RX 6800  |  WD Black SN750 1TB NVMe  |  Corsair RM750  |  Corsair H115i RGB Pro XT  |  Corsair 4000D  |  Dell S2721DGF  |
Fun Rig - AMD Ryzen 5 5600X  |  MSI B550 Tomahawk  |  32GB G.SKILL 3600 CL16 4x8GB |  AMD Reference 6800XT  | Creative Sound Blaster Z  |  WD Black SN850 500GB NVMe  |  WD Black SN750 2TB NVMe  |  WD Blue 1TB SATA SSD  |  Corsair RM850x  |  Corsair H100i RGB Pro XT  |  Corsair 4000D  |  LG 27GP850  |
https://linustechtips.com/topic/1329839-webcam-lighting-help/#findComment-14671276
