I recently built a friend a pc, https://pcpartpicker.com/user/2024jrb1/saved/9LrPFT, and long story short, their house was not wired for ethernet and the motherboard had no wireless card. They have manjaro linux, and they ordered a netgear wifi card (a7000), but it would not work with drivers. They are sending it back, but in the meantime, what is a good wifi 6 card (bluetooth is a +), that will work reliably on manjaro? I have seen some good things about cards with the intel ax200 chip, but wanted to check with y'all on the best thing to get.
I liked the look of this TP link card, and it has the intel chipset. Is this good? What about the intel NVME one?
https://www.amazon.com/TP-Link-Bluetooth-Ultra-Low-Archer-TX3000E/dp/B07ZV2CJL2/
https://www.amazon.com/Intel-Wi-Fi-Gig-Desktop-AX200-NGWG-NV/dp/B085M7VPDP/
https://linustechtips.com/topic/1329620-best-linux-wireless-card/
2 minutes ago, Nayr438 said:
On Manjaro, this should satisfy the Netgear USB Card.
In terms of best compatibility, anything Intel based. The ax200 is supported since Kernel 5.1
Tried the exact package, still did not work. I also think that the netgear device was weird with connecting. Probably going with the ax200 is our best bet.
I haven't used it a lot, but the AX200 seemed to work well for me.  The AX210 is potentially even better if you're on kernel 5.10 or newer as it will support WiFi 6e in a later kernel, but works fine on WiFi 6 right now.  I get better speeds on WiFi 5 (AC) on the AX210 than the AX200.
