First PC build help
Oh boy here we go:
1 hour ago, DrowningShark said:MotherBoard:
Gigabyte B550 Vision d
There are straight up better boards for cheaper. Unless you want it specifically for the looks, don't get it.
A board like a MSI B550-A Pro will give you the same performance, but for much cheaper.
1 hour ago, DrowningShark said:CPU:
AMD Ryzen 9 5950x
This is straight up wasted money. Go for a 5600X, which will give you the same gaming performance for much, much cheaper.
QuoteGPU:
AMD Radeon 6700xt
Use the money you save from the previous 2 components and upgrade this if possible. If availability doesn't allow you to, it's still a good GPU for competitive games.
QuotePSU:
Corsair RM 850X
Very good PSU. Has shown to be very relieable in terms of handling the power spikes from RTX3000 and RX6000 GPUs.
QuoteRAM:
Crucial Ballistix 32GB (4x8) 3600mhz CL16
Good RAM and great for the price aswell. But really think about if you need 32GB. For gaming - especially competitive games - you don't need more than 16GB.
QuoteOS Storage:
2TB m.2 Firecuda PCIeGen4
The SSD generally is fine, but you'll again overspend on a Gen4 drive that won't give you any performance or noticeable upgrade.
You could go for a 2TB WD Blue SN550 for much cheaper and won't notice any difference.
There are usecases for a Gen4 SSD, but yours isn't one of them.
QuoteIs this rig okay?
If you like to burn money, sure. Otherwise i'd change quite a lot.
Rather save the money on the components i talked about and get a better monitor, mouse, keyboard and headphone rather than overspending on a 16 core CPU. This way you'll be more competitive. More expensive is not neccesarily more better when it comes to PC components. Or upgrade the GPU 1 tier up. The performance you'd end up with is going to be better than the build you posted.
