4 minutes ago, Thomasas said:
I started my first pc build back in October and still haven't been able to get a gpu for my cpu. I need something to complement my ryzen 5 5600x. Any recommendations and or help getting a gpu.
Welcome to the club. Sign up for online alerts, enroll in the newegg product Shuffle if you can, and keep checking with your local stores. Good luck.
https://linustechtips.com/topic/1328548-need-help/#findComment-14661259
I recommend a 3060ti with it but if you can find one
https://linustechtips.com/topic/1328548-need-help/#findComment-14661270
