I need help please
I did a custom built almost 6 months ago and I almost never has an issue with it. Today I had this issue where the computer motherboard would not boot up to my O.S drive. It keeps on saying:
reboot and select proper boot device or insert boot media in selected boot device
I tried booting up via a windows installer usb to scan for any problems, but it did not boot up on to the usb either.
can someone help please
Specs:
WD blue 2tb HDD
seagate 200gb HDD
amd Ryzen 3200g
Windows 10 pro
2x 4gb ddr4 Crucial Ballstix RAM
I barely even use it
https://linustechtips.com/topic/1328483-drive-not-booting-up/
Just now, Acxd__OnTwitch said:
Have you tried disconnecting every drive, even the OS Drive and booting off a Windows Media Creation USB, I seen you had tried that but was that with everything disconnected?
When I inserted the usb the drive was not disconnected
https://linustechtips.com/topic/1328483-drive-not-booting-up/#findComment-14660768
1 hour ago, Acxd__OnTwitch said:
Lmk the outcome!
So it booted up into windows! Now the problem is when I login, it says preparing windows. Then it says that windows can’t login into your account. It sends me into a temporary account.
https://linustechtips.com/topic/1328483-drive-not-booting-up/#findComment-14660937
Okay that's a step forward! So it boots into windows with the drives now connected? If so that's great! I'm unsure on how you could fix the Windows issue though. I would personally Google it and see if someone has a solution or contact Microsoft. Hopefully everything starts working properly soon!
https://linustechtips.com/topic/1328483-drive-not-booting-up/#findComment-14660957
Thanks for the help 😊
https://linustechtips.com/topic/1328483-drive-not-booting-up/#findComment-14661995
