Hi. A quick question. I just bought an ASUS ROG Strix B550 Gaming-F WiFi6. I was kind of excited thinking my phones would be able to charge properly from the ports on it, at the very least, the USB 3.2. This doesn't seem to be the case. I'm wondering if there's a way to increase the output so my phones charge from my desktop faster?
Happy to help.
ASUS ROG Strix B550-F Gaming (WiFi6)\\Ryzen 3 3100 OC 4.5GHz @1.26V\\Corsair H60\\G. Skill Ripjaws V DDR4 2666 CL19\\WD Black SN750 512GB PCIe 3.0 NVMe\\WD 1TB Storage HDD\\EVGA 600B\\Power Color Radeon RX6600 XT 8GB\\ASUS TUF Gaming 23.8" IPS 144Hz@1080p\\Corsair 220T RGB\\Corsair K55 RGB Pro\\Logitech G402 Hyperion Fury
https://linustechtips.com/topic/1328203-increase-usb-wattage-output/
I don't think you can. Just get a proper charging plug for your strip.
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
Not that I know of... The USB ports on a motherboard aren't meant for charging, that's what chargers are for. They're used for data transfer to and from your PC.
The only fast charging ports I've seen on PCs were front panel connectors that were directly connected via SATA Power connectors.
USB 3.2 has to support 5V charging with 900mA or 1.5A, which is nothing for modern phones.
My Rig: AMD Ryzen 5800x3D | Scythe Fuma 2 | RX6600XT Red Devil | B550M Steel Legend | Fury Renegade 32GB 3600MTs | 980 Pro Gen4 - RAID0 - Kingston A400 480GB x2 RAID1 - Seagate Barracuda 1TB x2 | Fractal Design Integra M 650W | InWin 103 | Mic. - SM57 | Headphones - Sony MDR-1A | Keyboard - Roccat Vulcan 100 AIMO | Mouse - Steelseries Rival 310 | Monitor - Dell S3422DWG
USB power is negotiated by both the downstream and upstream ports. The upstream will only advertise as much as its capable of putting out and the downstream will only accept either the maximum of the upstream or a lower power level depending on how the device is configured. You can't change how much power delivery comes from an upstream port. If your mobo has high power ports they're usually marked as such. At the end of the day the only way you're going to get faster charging is to get a device intended for charging which mobo's are not.
CPU: Intel i7 - 5820k @ 4.5GHz, Cooler: Corsair H80i, Motherboard: MSI X99S Gaming 7, RAM: Corsair Vengeance LPX 32GB DDR4 2666MHz CL16,
GPU: ASUS GTX 980 Strix, Case: Corsair 900D, PSU: Corsair AX860i 860W, Keyboard: Logitech G19, Mouse: Corsair M95, Storage: Intel 730 Series 480GB SSD, WD 1.5TB Black
Display: BenQ XL2730Z 2560x1440 144Hz
