Not sure what the cause is but you could try removing your graphics drivers using DDU (Display Driver Uninstaller) in safe mode, reboot and reinstall the latest driver when logging back in.
To force Win10 into safe mode hold down the power button when you get to thatt screen, repeat this three times and it should all you to boot into safe mode
https://linustechtips.com/topic/1327922-i-need-help/#findComment-14657148
