First off, I just did a free malwarebytes test and it found 13 items. Deleted then restarted computer. I looked up my network by via Microsoft Network Monitoring then i saw <Unknow>. What should i do? All malwares are <Unknow> in system (also one of those <Unknown> things carry a ton of IPv4 >UDP>HTTP and IPv6 adresses and the other one only carry 1 IPv4 adress.)
https://linustechtips.com/topic/1327391-unknow-data-flow-in-network/
On 4/15/2021 at 4:00 PM, Mgsr2TkrrR said:
What should i do?
You need to get a thorough scan done to properly remove all traces of malware on your system. As good as MBAM is, it can’t clean up everything. Unfortunately, I don’t have the training to help you with that as this type of work requires special guidance. I’m not even sure LTT forums has a subsection for proper malware removal.
I’ll refer you to the MRU and BestTech.net forums. ‘flashh4’ is trustworthy and very helpful in the Malware Removal section of the latter forum. Just follow the forum instructions.
