Hi everyone,
When I started my computer today my keyboard (asus rog claymore) started to behave weirdly, if I decide to type regularly then the keyboard produces multiple strokes, like this if I  type like this you can see it  produces   more spaaaaces than it should and if I d daaare     to press  a keeeyy  for more   than aa miliisseecccond  it will repeeeeeeat the  stroke  1000xx
If I want to type normally, I have to micro-press one key at a time, from last shut down I haven't changed anything on my PC. Has anyone had something similar  before?
Thanks
https://linustechtips.com/topic/1327243-help-with-odd-behaving-keyboard/
6 minutes ago, Martines91 said:
Hi everyone,
Thanks
Plug in the keyboard to another PC and see what happens. If the same issue occurs, the keyboard could be faulty.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
It might be worth cleaning your keyboard.
  • Unplug your keyboard.
  • Take off the keycaps and wash them with water and a bit of dishwashing soap.
  • Clean off all the dust with a can of compressed air, or a cloth.
  • Use some isopropyl alcohol (at least 70%) and cotton swabs (a microfiber cloth or a small soft brush will also work) to clean the switches. You don't need a lot of alcohol.
  • Make sure the keycaps are dry and reassemble your keyboard.
Although, your issue sounds more like a software problem... maybe.
CPU: Ryzen 5 3600X            | Cooler: Deepcool AK400  | Motherboard: B550 Elite AX V2  | Storage: Samsung 980 Pro 1TB  |
RAM: Corsair Vengeance 16GB   | GPU: MSI RTX 3060 Ti    | Case: NZXT H440 (Red/Black)    | PSU: EVGA 650W G2             |
There's a setting in windows that controls this, type "Keyboard" into windows search  and press on the first one that comes up, and I think the setting you're looking for is repeat delay. Move the slider to the left to make it longer and see if that fixes your problem.
I have tried that, but it doesn't affect this, but I too think this is more of a software issue because as I said when I was turning off my PC last night it was all fine. By holding any button it multiplies itself by huge amount in a short moment. I know this will look silly but just typing letter a for 1 second results this: aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
It feels like any button gets multiplied instantly and typed super fast
good thing it was a software bug, I was going to say a switch or the controller on the board was going bad.  My Poker II will do this from time to time, but it's looking like I need to fix the solder on a few switches.
Project Gray Scale
Intel Core i7 6900k @ 4.2Ghz - Dominator 32GB DDR4 2400 CL10 - Samsung 970 EVO+ 1TB NVMe - 2 Samsung 840 EVO 1TB (Gaming and Sratch) - 2 Barracuda 2TB
Asus x99 Deluxe - MSI Aero OC GTX 1080Ti - Seasonic 760 XP² - Mod1PC Custom Cables - EKWB CPU & GPU Blocks Nickle/Plexi - EKWB D5 PWM
EKWB PE360 - Corsair ML120 (6)  - InWin 303- NK65 Entry Watermelon w/ Gat Laseron 70g (205g0 & Filmed) - Logitech G Pro x Superlight
Kanto YU2 - Sennheiser PC360 SE - Acer XF270HU
BUT DOES IT FOLD?! https://folding.extremeoverclocking.com/user_summary.php?s=&u=963814
