So recently switched from being directly connected to my router through ethernet to be connected to an extender instead. I've had issues were I'll randomly disconnect occasionally. Sometimes it will happen often and othertimes not at all. The disconnects are always really short, couple seconds at the most. Does this just have something to do with the nature of the wifi extender itself or could it be something else? Right now I'm looking into getting my drivers up to date with DriverEasy since I had a friend recommend it but an ideas people have out there would help.
https://linustechtips.com/topic/1327037-wifi-issues/
1 hour ago, RAM555789 said:
Updated drivers, still no change.
You are having the same issue as this other dude. Have you tried this solution?
Link:
System Specs
  • CPU
    AMD Ryzen 7 5800X
  • Motherboard
    Gigabyte AMD X570 Auros Master
  • RAM
    G.Skill Ripjaws 32 GBs
  • GPU
    Red Devil RX 5700XT
  • Case
    Corsair 570X
  • Storage
    Samsung SSD 860 QVO 2TB - HDD Seagate B arracuda 1TB - External Seagate HDD 8TB
  • PSU
    G.Skill RipJaws 1250 Watts
  • Keyboard
    Corsair Gaming Keyboard K55
  • Mouse
    Razer Naga Trinity
  • Operating System
    Windows 10
https://linustechtips.com/topic/1327037-wifi-issues/#findComment-14650800
Link:
Completely different. I'm on a desktop not a laptop, and my issues seem to be with my wifi extender. As I said I use to have an ethernet going directly to the router and now instead it goes to the wifi extender. I just can't figure out why I'll have a couple seconds of disconnect from the wifi extender and how it's super inconsistent with these disconnects.
https://linustechtips.com/topic/1327037-wifi-issues/#findComment-14652523
