What should I know while using gsync?
Go to solution Solved by Hairless Monkey,
Welcome to the variable refresh rate club. You may never leave.
I find that these settings in the Nvidia control panel work best in most games for a smooth experience with not too much added latency:
Gsync: On (duh)
Low Latency Mode: Ultra
Max frame rate: 160fps for 165Hz, 140FPS for 144Hz, etc. ( a few below your max refresh).
Power Management Mode: Max Performance
Vertical Sync: Fast
Gsync: On (duh)
Vertical Sync: Fast
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
Gsync: On (duh)
Vertical Sync: Fast
I've read some places that I shouldn't have Vsync on, and I've also read that fast vsync can cause stuttering under your refresh rate. Can you explain that to me? Also can you explain why I should use ultra and not on for low latency mode?
Vsync can cause more latency, but without it you can get some tearing even with Gsync on. You'll have to try them out to determine what you like best, These are the settings that I have personally settled on after trying lots of combinations.
Ultra prevents your system from pre rendering any frames, and so reduces latency. But it can reduce your frame rate, and can cause problems with certain games. I have never had an issue with it, though. "On" limits the pre rendered frames to 1, which is nearly as good, and may have better compatibility with more games.
BigBox (HTPC):
  • Display: None
  • 2.5Gb NIC
NAS:
  • Synology DS216J
Just now, HairlessMonkeyBoy said:
Vsync can cause more latency, but without it you can get some tearing even with Gsync on. You'll have to try them out to determine what you like best, These are the settings that I have personally settled on after trying lot's of combinations.
Ultra prevents your system from pre rendering any frames, and so reduces latency. It can reduce your frame rate, and can cause problems with certain games. I have never had an issue with it, though. "On" limits the pre rendered frames to 1, which is nearly as good, and may have better compatibility with more games.
Alright, that makes sense. Thank you!
