CPU cooler
Solved by Omar.B,
9 hours ago, RvG Iced said:
no both are overkill for cpu like this one without mentioning AMD cpus are easy to cool , a cooler master hyper 212 or the v2 will handle it just fine if you still have concerns then go with one the coolers you provided both of them can handle a R9 5900x
