Greetings, guys
Got a question, hope anyone can guide me.
In the photo down below, on the installed CPU AIO could you please suggest if the Fan on CPU AIO Rad be pushing the air in or out ?
I am not really familiar with it and wanted a quick answer for it? at the moment I have mounted so when i put my hand on front of the fan (inside ) it pushes air
https://linustechtips.com/topic/1326297-cpu-aio-fan-question/
The fan is sucking air out of the case.
I also have a 120mm AIO in the back of my case, and it is mounted in the same way yours is.
I do feel air movement, but it's not pushing on my hand.
PLEASE STOP [Killing] ME I WILL GIVE Y OU ANOTHER DEAL.
https://linustechtips.com/topic/1326297-cpu-aio-fan-question/#findComment-14644986
I was thinking maybe it needs to be flipped?
https://linustechtips.com/topic/1326297-cpu-aio-fan-question/#findComment-14645002
