Help making my build cheaper?
Solved by GorujoCY,
Here i have formed a Good build here:
and cut about 280 pounds of your budget. The rx 560d can be unlocked with a simple bios flash here, you can also search on the internet on how to do it, there are many guides out there.
Unfortunately this has to be bought on gearbest too because of the gpu shortage we are facing so I hope you can do that. Enjoy light gaming
Also your gpu can do triple monitor as long as your monitors are separate from HDMI, DisplayPort and DVI, if you only have 2 HDMI for example, you can use a DVI to Hdmi adapter
