Hey, so I own a Lenovo ideapad flex 5 with ryzen 3 4300u with 8GB RAM and I found out that it has a second m.2 (PCI-e 3.0) slot (2280) in addition to the already occupied (2242) one.
The ssd this laptop came with is quite tiny for me (250GB), so I figured It'd be nice If I occupy the second slot with another 500GB NVMe ssd.
Consider that I'll use whichever of the 2 drives is faster for the system allocated partition as well as page file.
Question is, is there any actual real world benefit to buying something speedy and fancier like a Samsung EVO Plus (3500/3300 r/w) or should I just go with whatever is the cheapest 500GB one that goes up to 2000/1500 r/w.
Are there any actual benefits to having 1GB extra max speed cap or is it just an overkill anyways?
Things I do: some light engineering stuff (CAD, Matlab), photo editing (Photoshop), light gaming (WoW, CS:GO), I play around with Linux distros in VMs and I do office work.
I am a seeker of performance (deminished by a tight budget lol) so value it is for me.
If there are any benefits (e.g. faster page file r/w, quicker load times) then I could go for the Samsung one and max out the PCI-e 3.0 interface...but if it's just BS, I'd rather not.
No ram slots (I know it sucks, but I can actually multitask with no problems considering my workloads even when I open everything just to watch it struggle, it's still snappy enough), so I do have a lot of page file actions going on sometimes, so that's the main think I care to boost with a faster drive, if possible.
Thanks in advance! 🙂
Cheers!
P.S. Also how would that go for the battery life? I assume it'll drain faster with 2 drives powered on.
A faster SSD would finish file transfers in less time so that'd reduce power usage I guess.
If the workload consists of tiny transfers happening all the time that wouldn't be valid, tho, I also guess.
https://linustechtips.com/topic/1326069-nvme-speed-and-value/
Cheers!
You could just go with a cheap but good nvme ssd like sn550, it is 2280 afaik. IMO, there is not a whole lotta benefits from having multi-gigabyte transfer speeds like that unless you're transferring large files all day, otherwise you don't really get that speed, what really matters in everyday performance is random read/write.
Attention is what makes life meaningful.
Also, please quote me for a reply. 🙂
https://linustechtips.com/topic/1326069-nvme-speed-and-value/#findComment-14643438
Yeah, I'd be bottlenecked way before nvme speed caps by my external storage medias and LAN,WAN link speeds haha.
https://linustechtips.com/topic/1326069-nvme-speed-and-value/#findComment-14643441
Yeah of course, no point in that. Those are more needed in servers where they actually serve a purpose other than being a number on the marketing page.
https://linustechtips.com/topic/1326069-nvme-speed-and-value/#findComment-14643447
