Hey all,
I need some advice as regards to the fan/airflow layout in my Meshify S2. Right now, I have the CPU double rad mounted on the front, as it did not fit at the top. That means that I had to put the 2 intake fans at the bottom of the case (see image). The single outtake fan is in the default case position, at the top left.
My worry is that there isn't enough air going into the case, as there's only 2 140mm intake fans at the bottom blowing directly into the GPU (I'm mid-upgrade atm - 6800 XT coming soon!) and the right one is nearly completely blocked, and that might mean that my components just won't have enough fresh air. Right now my CPU (3900X) runs rather hot at around 70-80 degrees under load, and I fear it will only get worse when I add a beefy GPU.
Any advice?
(red = blowing outwards, blue = blowing inwards)
https://linustechtips.com/topic/1325250-help-with-case-airflow-layout/
