Budget (including currency): $600 USD
Country: United States of America
Games, programs or workloads that it will be used for: I would like to use this pc later on with some triple A titles and some editing and recording
I don't need any peripherals, I don't need any storage I already have some for this build.
Here is my build that I am looking at, any help would be appreciated:
CPU: AMD Ryzen 3 3200G 3.6 GHz Quad-Core Processor  ($169.99 @ Newegg)
Motherboard: MSI B450M BAZOOKA MAX WIFI Micro ATX AM4 Motherboard  ($89.99 @ Amazon)
Memory: Silicon Power 16 GB (2 x 8 GB) DDR4-3200 CL19 Memory  ($81.97 @ Newegg)
Case: Thermaltake S100 Snow Edition MicroATX Mini Tower Case  ($69.99 @ Amazon)
Power Supply: ARESGAME AGV 500 W 80+ Bronze Certified ATX Power Supply  ($39.99 @ Amazon)
https://linustechtips.com/topic/1324845-help-w-pc-build/
170 is steep for a cpu that goes for $99 and is 4c/4t. I would def get a 10400/11400. I also would not trust that power supply.
https://linustechtips.com/topic/1324845-help-w-pc-build/#findComment-14634723
I redid my list a little bit, I'm not for sure if this is much better or not.
CPU: Intel Core i5-10400 2.9 GHz 6-Core Processor  ($164.99 @ Best Buy)
Motherboard: ASRock H510M-HDV Micro ATX LGA1200 Motherboard  ($76.98 @ Newegg)
Memory: G.Skill Aegis 16 GB (2 x 8 GB) DDR4-3000 CL16 Memory  ($69.99 @ Newegg)
Case: Thermaltake Versa H17 MicroATX Mini Tower Case  ($39.99 @ Newegg)
Power Supply: EVGA BQ 600 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($42.75 @ Newegg)
Total: $394.70
https://linustechtips.com/topic/1324845-help-w-pc-build/#findComment-14634738
Total: $394.70
Power supply is still a bit weak.
PCPartPicker Part List: https://pcpartpicker.com/list/NbqZ3Z
Motherboard: ASRock B460M-ITX/ac Mini ITX LGA1200 Motherboard  ($103.99 @ Newegg)
Storage: Western Digital Blue SN550 500 GB M.2-2280 NVME Solid State Drive  ($59.99 @ Amazon)
Case: Thermaltake S100 MicroATX Mini Tower Case  ($64.99 @ Newegg)
Power Supply: Corsair CX (2017) 450 W 80+ Bronze Certified ATX Power Supply  ($51.64 @ Amazon)
Total: $515.59
Generated by PCPartPicker 2021-04-10 13:37 EDT-0400
funnily enough itx boards are cheaper so you might want to get an itx case like an h210. Still included some storage in case you only have a hard drive
https://linustechtips.com/topic/1324845-help-w-pc-build/#findComment-14634753
Total: $515.59
Thanks so much!
https://linustechtips.com/topic/1324845-help-w-pc-build/#findComment-14634765
