A machine learning question
Go to solution Solved by igormp,
Both are rule-based systems, but with the decision tree you have it more "automated" since you can see which variables bring you the most value. As an example, with ID3 you'd have the information gain and entropy for each attribute, which would be calculated based on your available dataset, whereas with a regular, old-style rule-based system you'd do so by hand.
FX6300 @ 4.2GHz | Gigabyte GA-78LMT-USB3 R2 | Hyper 212x | 3x 8GB + 1x 4GB @ 1600MHz | Gigabyte 2060 Super | Corsair CX650M | LG 43UK6520PSA
ASUS X550LN | i5 4210u | 12GB
Lenovo N23 Yoga
