Budget (including currency): N/A
Country: U.S.
Games, programs or workloads that it will be used for: VALORANT, Apex Legends, R6S, GTA *(Maybe)*
So I have a Corsair 4000D build with 2 stock fans, 3 Coolmoon fans, X570 MSI MPG Wifi, AMD Ryzen 3700x, and I have a 3060ti that I will be hopefully bagging within the next month or so, but I was wondering whether or not I should throw in my AMD RX 470. Fairly new to PC builds, and was wondering if it would be a good temporary GPU until I get that 30 card, and why or why not. Thank you.
https://linustechtips.com/topic/1324389-need-help-with-pc-plan/
Country: U.S.
The RX 470 is still a decent GPU, for what your doing expect decent frame rates. When you get your 3060ti just make sure too uninstall your radeon drivers and install the 3060ti ones
geometry is hard
b550 > x570
https://linustechtips.com/topic/1324389-need-help-with-pc-plan/#findComment-14631856
Country: U.S.
I don't see any negatives of putting it in, at least you could use the computer, you probably would not be able to do a ton of gaming, but you could use it to both use and test the computer.
https://linustechtips.com/topic/1324389-need-help-with-pc-plan/#findComment-14631857
5600x is available, better than 3700x.
Yes 470 is a good one.
https://linustechtips.com/topic/1324389-need-help-with-pc-plan/#findComment-14632298
