Budget (including currency): 1100 CAD
Country: Canada
Games, programs or workloads that it will be used for: Outriders, Mass Effect Legendary Edition, Sims 4 @ 60 fps lol, Unreal Engine for game dev
Other details
I'm re-using some parts from a pre-built that I have and buying the rest. The pre-built is a ACER Predator Orion 3000 I currently plan to use the GPU, CPU from the pre-built which are all listed in the build as purchased. The budget for the remaining parts is about 1100CAD.
The more USB 3 connections the better and I prefer to have built in wifi and bluetooth, I play on a 1440p monitor with 165hz and have a second 1080p monitor that I may potentially upgrade in the future to another 1440p monitor. Upgrading to a 3070 would be nice if prices ever come down :sadge:
I like RGB and quiet fans. So if you got a better radiator to recommended i'd be happy to hear any other suggestions
I'm looking for advice on the remaining components before I buy them. If there are any recommended changes please let me know. Below is the PCPartPicker list which has the price listed in USD because my smooth brain couldn't figure out how to change it 🙂
https://linustechtips.com/topic/1324102-building-my-first-pc/
