Budget (including currency):
Country: USA
Games, programs or workloads that it will be used for: Star trek Online, Star Wars the Old Republic, Video Editing.
Other details I am working on building a new gaming PC from an older gaming rig I had. I am salvaging 2x Radeon rx570 graphics cards, 2x 1Tb 3rd Gen NVMe M.2 drives, 2x 1Tb HDDs, 2x HyperX Fury 4Gb DDR4 memory, and an AMD Ryzen 7 1700x cpu from the old system. I have bought new an ASUS ROG STRIX B550-A motherboard, a Lurker V360 AIO CPU cooler, and a Hiearcool 750w RGB modular power supply. I am having trouble sourcing a decent case that can get to me in a reasonable amount of time. I am also considering doing liquid cooling on both the graphics cards, but I am having trouble finding a good solution.
https://linustechtips.com/topic/1324057-rebuilding-my-system/
Country: USA
How much are you planning to spend?
https://linustechtips.com/topic/1324057-rebuilding-my-system/#findComment-14629376
Country: USA
And what color? If you have a preference.
https://linustechtips.com/topic/1324057-rebuilding-my-system/#findComment-14629382
Just now, KLW said:
I am looking to spend around $100 for the case. As for the GPU liquid cooling I am planning to spend no more then $200 for it.
What kind of case are you looking for? Just like a basic PC case? Or one with like RGB fans and stuff? Do you need a certain amount of USB ports?
https://linustechtips.com/topic/1324057-rebuilding-my-system/#findComment-14629403
My only real requirement for the case is it needs to fit the 360mm AIO, preferably in the top.
https://linustechtips.com/topic/1324057-rebuilding-my-system/#findComment-14629407
