Hello,
I am hoping someone can help me out here. I moved my PC case from the floor, under the desk, onto my desk. The reason for my PC being on the floor was because the fans are so damn loud!
CPU Cooler: Artic Freeze II (2 Fans)
Case: BeQuite DX500 (https://www.bequiet.com/en/case/1854)
CPU: AMD 3600 (very slight OC with EZ Tune)
So ever since new this this has been loud. I picked the case and the cooler based on the recommendations that they were quiet so I'm really unsure what is wrong here. Fans being used are BeQuiet Pure Wings, the ones that came with the case (x3)
Rear Fan: Sucks air out
Top Fan (Rear): OFF
Top Fan (Front): Sucking air in
CPU Rad (Front Mounted) Sucks air out of case
The fans are never quiet, its not as though the thing gets hot and the fans ramp up. It's more like there is a constant low humming of the air moving, as though the fans are spinning too fast.
No dust in PC case. No dust in fans!
I suspect I have configured something wrong somewhere!
Thanks
https://linustechtips.com/topic/1323927-fan-noise/
You should try setting a manual curve.
First, go to the Advanced Mode and to the "Monitor" Section. There is a button in there for calibrating the fans. The motherboard will find the minimum voltage/PWM signal for each fan. Once you do that, you can go back to the EZ mode if you want, or stay in advanced mode a change the fan curve settings.
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
https://linustechtips.com/topic/1323927-fan-noise/#findComment-14628473
I tried your suggestions and it didn't make any difference. Interestingly I couldn't adjust the chassis fans manually, well I could, but I couldn't lower them from 50% speed. See pictures below.
https://linustechtips.com/topic/1323927-fan-noise/#findComment-14628519
You ran the QFan tuning?
BigBox (HTPC):
  • Display: None
  • 2.5Gb NIC
NAS:
  • Synology DS216J
https://linustechtips.com/topic/1323927-fan-noise/#findComment-14628521
Just now, RaggedCorners said:
Yes - The option at the top of the first picture.
It took about 45 seconds to complete.
If they are 4-Pin, PWM fans, then you can switch them to PWM mode and try the tuning again. If they are 3-pin, non-PWM fans, then you can switch them to DC mode and try the tuning again. You might have to save settings and reboot for those changes to stick before re-running the tuning.
Otherwise, you SOL. Your fans have a high (and noisy) startup voltage.
BigBox (HTPC):
  • Display: None
  • 2.5Gb NIC
NAS:
  • Synology DS216J
https://linustechtips.com/topic/1323927-fan-noise/#findComment-14628535
