A few months ago I "finish" a pc build in a old IBM PS/2 case, I really like how it turned out, but I can't figure out how to do the cooling. A picture of the pc settup ATM, is attached. I have been using the pc with out the top for sometime, but I feel like it isnt finished. When I put the top on the CPU's idel temp go'es op with 15-20 degrees c. Hope anyone has some solutions.
(Sry for my poor English)
https://linustechtips.com/topic/1323917-cooling-help/
Make sure PSU has an opening for its fan. You may need to put an opening above the CPU cooler fan. Find some fans, and make some holes, to get some air flow in the case.
Something like these maybe:
https://www.amazon.com/Wathai-40mm-20mm-Brushless-Cooling/dp/B07Q2K3WYM/ref=sr_1_4?dchild=1&keywords=20mm+case+fan&qid=1617916452&sr=8-4
https://linustechtips.com/topic/1323917-cooling-help/#findComment-14628732
This is due to poor airflow.
1. Make some holes on the pc cover directly above the cpu cooler.
2. Install exhaust fans. Maybe one or two.
  • CPU
    9900KS @ 5.0 avx offset 0/ cache 4.7/ @1.33v
  • Motherboard
    asus strix ROG z390-i
  • RAM
    8gb x2 G.skill ddr 4 3600 (OCed to 4000 17-19-19-39 @1.4v)
  • GPU
    Asus Strix OC RTX 3080 10GB
  • Case
    Corsair 280x Crystal
  • Storage
    1tb Samsung SSD + 2x (512gb Samsung) SSD
  • PSU
    Seasonic GM 650 650Watt Gold (semi-modular)
  • Display(s)
    LG34gk950g
  • Cooling
    H115i platinum/ 2x NF-A14 (GPU intake)/ 2xNFA14 (H115i radiator exhaust fan) 2x Corsair ML PRO 140(front intake) / 1x NF-A8 (exhaust)/ 2 x Corsair LL 120 (GPU deshroud fans)
  • Keyboard
    Corsair K70 LUX MX RED/ Microsoft Designer Keyboard Bluetooth
  • Mouse
    Corsair Harpoon RGB
  • Sound
    Audioengine A2+/ Audioengine d1 dac/ B&O h6
https://linustechtips.com/topic/1323917-cooling-help/#findComment-14629417
