Budget (including currency): GBP
Country: UK
Games, programs or workloads that it will be used for: gaming, graphics rendering, streaming and cyber security training
Other details: current parts are as below:
1) AMD Ryzen 9 5900X
2) Gigabyte AMD AM4 X570 AORUS XTREME D4 E-ATX Motherboard
3) Samsung 870 QVO 8 TB SATA 2.5 Inch Internal Solid State Drive
4) Thermaltake Floe Riing RGB 360 TT AIO Water-Cooling CPU Cooler
5) CORSAIR VENGEANCE RGB PRO 128GB
What would be the best PSU and GPU to run with this?
https://linustechtips.com/topic/1323725-need-advice-on-psu/
litterally anything you can near-ish MSRP that isnt 3 years old
ADATA XPG CORE Reactor 750 W 80+ Gold Certified Fully Modular ATX Power Supply (COREREACTOR750G-BKCUS) - PCPartPicker
MSI MPG A-GF 750 W 80+ Gold Certified Fully Modular ATX Power Supply (MPG A750GF) - PCPartPicker
id take a look at either one of these.
Corsair RM (2019) 750 W 80+ Gold Certified Fully Modular ATX Power Supply (CP-9020195-NA) - PCPartPicker
RM is also an option.
gives you the option of plugging in a GPU up to a 3090 if you ever wanted to
https://linustechtips.com/topic/1323725-need-advice-on-psu/#findComment-14626809
I would recommend you recommend getting the RTX 3090 along with a 80+ certified 1000W power supply from a reputable brand.
Ryzen 5 2400G -B450M DS3H Motherboard (Gigabyte) - 16GB RAM (CL 16, 3000MHz) - 240GB SSD (Kingston) - 1TB HDD(Seagate) - 450W PSU (Corsair)
https://linustechtips.com/topic/1323725-need-advice-on-psu/#findComment-14626815
