Hi all,
so my issue is i got an old pc of someone some parts were broken and i got replacements, got it to post fine without a gpu, installed windows 10 pro 64bit and everything was fine till i turned it off switched the psu off with the switch on the back then pressed the power button to make sure there is not electricity lingering in it and inserted the gpu plugged the 6 pin into it and tried to power it on but it would run for 10 seconds and then power off and stuck in that loop so i turned it off with the switch again did the whole power thing and then plugged the gpu out but now its doing the boot loop thing without the gpu as well, please help!
motherboard = msi b75ma-e33
cpu is an i5 and 8 gigs and 8 gb or ram its the kingston hyperX red
600w evga 80 plus psu
i tried reseating the ram and pulled the cpu and 24 pin out and back in, not too sure what to do next.
https://linustechtips.com/topic/1323695-pc-not-starting/
5 minutes ago, Salvadion said:
Hi all,
when your GPU is connected can you enter the bios? does the system turns off even from there?
https://linustechtips.com/topic/1323695-pc-not-starting/#findComment-14626658
Yeah i pulled everything out except the cpu and cpu cooler didnt want to play with thermal paste again, the 20+ 4 pin didnt want to go in fully i gave it a bit of help and its working now so i am gonna start work now and play around with the gpu afterwards, wish me luck!
https://linustechtips.com/topic/1323695-pc-not-starting/#findComment-14626677
