Hello
I am going to be building a new system in the near future. I'm going till wait till Haswell launches and and go with the Z87 platform. My budget is £700 ($1100) The case im currently looking at is a Corsair C70. Has anyone got a better Recommendation with is a bit cheaper. I will be mounting a H100 in the top, 2 HDD's and a Radeon HD 7870.
Thanks
https://linustechtips.com/topic/13232-case-recommendation/
Fractal Design Define R4 is pretty much the name you'll se pop up around the forum. No idea of how they compare at price
I agree, Fractal will be the recommendation of many, although I would suggest the Arc R2, opposed to the define R4 for sheer cooling performance. The Arc can mount a 240 rad in the roof and comes in cheaper than the Corsair C70.
Dependent on if you can sacrifice extra noise for increased thermal dissipation over the Define R4 and, If the prospect of cleaning dust build up form inside your case every week isn't too taxing, I'd go for the Arc R2!
You can also check out the H100 Compatibility thread http://linustechtips.com/main/topic/1523-h100-compatibility-thread/'>here which will give you an in-depth insight into cases that suit your requirements.
Hope this helps.
https://linustechtips.com/topic/13232-case-recommendation/#findComment-142268
Fractals are solid.  Define R4 can be had with Window or no Window.  Also look at Nanoxia Deep Silence 2...similar case at similar price.  The Corsair Carbide 500R is on sale now too and I'd highly recommend that.  Depends on your aesthetic tastes.
My Stuff:  Corsair Obisidan 550D - Phobya Nano-2G 120mm x 5 - Corsair H100i - MSI Z77A-GD65 Gaming - Intel 3570K - G.Skill 8GBx2 1866 - EVGA ACX GTX 780 3GB SuperClocked(Step Up to 780 Ti) - Samsung 840 500GB SSD - WD Black 1TB x 2 - LG Blu-ray - ASUS VG248QE + ASUS PB278Q - Corsair M65 with MM400 Pad - Ducky Shine II MX Brown with Gray/White Keycaps - Corsair K70 MX Red - CoolerMaster Quickfire TK MX Brown - Ducky Pro2 MX Blue with Gray PBT Keycaps - Ducky Pro2 MX Clears with Gray/Blue PBT Keycaps - Ducky Pro2 MX Browns with Light Gray and White PBT Keycaps
https://linustechtips.com/topic/13232-case-recommendation/#findComment-142864
As has already been mentioned, Fractal Design has a couple of great options with the Define R4 (my case) and the Arc Midi R2. Corsair has the 300r and BitFenix has the Shinobi. Here are some current prices for comparison:
  • Fractal Design Define R4: $89.99 @ Micro Center
  • Fractal Design Arc Midi R2: $89.99 @ NCIX
  • Corsair 300r: $64.99 (post-rebate) @ Micro Center
  • BitFenix Shinobi: $69.99 @ Newegg
Intel Core i7-5930K | Noctua NH-D15S | ASUS X99-M WS | 32GB (4 x 8GB) G.Skill Ripjaws V 2666MHz | MSI GeForce GTX 980 Ti Gaming 6G | Samsung 850 Pro 512GB | Seasonic 660XP2 | Phanteks Enthoo EVOLV
LG 34UM95-P w/ Ergotron MX  | O2/ODAC | Audioengine A5+ w/ AS8 | Sennheiser HD 598 | Ducky Shine 3 | Cooler Master Storm Spawn
https://linustechtips.com/topic/13232-case-recommendation/#findComment-142971
Thanks for the suggestions. After reviewing the cases i'm going to get the Fractal Design Define R4, as the computer will need to be quiet.
Should i replace the stock fans on the case and H100 with Noctua NF-F12's or leave them as they are?
https://linustechtips.com/topic/13232-case-recommendation/#findComment-143708
You can also check out the H100 Compatibility thread here which will give you an in-depth insight into cases that suit your requirements.
Hope this helps.
Anybody should be cleaning the dust out from there case regardless!
https://linustechtips.com/topic/13232-case-recommendation/#findComment-143814
If you have the budget for it replace the fans, The stock corsair fans are extremely loud!
https://linustechtips.com/topic/13232-case-recommendation/#findComment-143815
Also good choice on the R4, I've done alot of builds in them, They are possibly my favourite case on the market at the moment.
https://linustechtips.com/topic/13232-case-recommendation/#findComment-143816
If I were you I would avoid the C70 as it has low air-clearance through its hard drive cages.
(As you can see in this TTL's video )
I'd recommend you go with Corsair 350D instead. It's high quality mATX case with good looking window.
You can fit your 2 HDDs easily. It's H100/H100i compatible (It's Corsair what do you expect).
https://linustechtips.com/topic/13232-case-recommendation/#findComment-143886
The build has to be quiet so i'll replace the fans. Can the Noctua fans be controlled in Asus's AI Suite 2? I'd like to set fan curves on them.
So far with my experience with AI Suite 2 there isn't control for normal 3 pin fans, But the H100i will be able to control the fans for you.
In all honesty Noctua fans are so quiet that you could get away with running them directly off the psu at 12 volts and not even know they were on!
https://linustechtips.com/topic/13232-case-recommendation/#findComment-143921
3 pin fans are controllable with AI Suite 2. Why would they not be?
https://linustechtips.com/topic/13232-case-recommendation/#findComment-144007
I'm not sure, But I've not been able to get my fans to run at anything other than 12v off of the motherboard with AI Suite, I only played around with it for 15 minutes or so ut so it could be quite possible.
I just ended up pulling out my aquaareo 5 lt and hooking that up. So much overkil for my little APU spare parts rig :D
https://linustechtips.com/topic/13232-case-recommendation/#findComment-144023
The H100i has two dual fan pin connectors so you can control up to 4 fans directly from the H100i.  My system is set up that way; the dual rad fans and the dual front fans are controlled by the CorsairLink.
https://linustechtips.com/topic/13232-case-recommendation/#findComment-145789
For quiet fans, you can consider Noctuas, Nanoxias, Be Quiet! fans, or just stick with the stock Fractal Design Silent Series R2 fans since they are very quiet and quite sexy. I myself stuck with the Fractal Design Silent Series R2 fans, but I did throw in an additional front intake and floor intake (also Fractal Design Silent Series R2s) for high positive pressure. All the intakes are hooked up to the built-in fan controller at 5V while the back exhaust is at a constant 7V using an in-line resistor. If you don't get the windowed version of the case, you may not care as much about aesthetics. If you couldn't care less about aesthetics, then, yes, Noctuas are going to be the quietest.
https://linustechtips.com/topic/13232-case-recommendation/#findComment-147688
Great choice going with the Define R4. My original case was a Corsair 300R and I moved to the R4 and have not regretted the decision at all. Case has been really fun to build in. And the build quality is out of the world compared to other cases.
As far as your cooling solution goes. If you are planning on getting an H100 and replacing the fans then I would personally suggest you take a look at getting a Swiftech H220. Yes, it costs more than the Corsair coolers but you won't need to replace the stock fans. I can tell you from experience that the H220 can be extremely quiet if you want it to be.
https://linustechtips.com/topic/13232-case-recommendation/#findComment-148274
The NZXT Phantoms are way too plastic-y and the panels on the Corsair 300r are too thin. The Fractal Design cases, on the other hand, offer some beefy steel construction, although this makes them less than ideal for LAN events, if you're into that kind of thing.
https://linustechtips.com/topic/13232-case-recommendation/#findComment-149644
Whether or not the motherboard can control 3 pin fans off the case fan headers depends on the the motherboard. My Asus Maximus V Gene is able to control the front 180mm, 3-pin fan off a case fan header, but then again, the case fan headers on this mobo are all 4-pin PWM headers.
Gaming PC
  • SSUPD Meshlicious White Full Mesh
  • Corsair SF650 Platinum
  • ASrock B550 Phantom Gaming ITX/ax (Won a giveaway from OptimumTech)
  • Ryzen 5 5600X w/ Scythe Big Shuriken 3
  • 2x8gb G.Skill Flare X @3200 CL14
  • PowerColor Gigabyte RX 6750 XT
  • Storage:
    • Samsung 970 Evo NVME
    • Samsung 860 Evo 2.5"
    • MyDigitalSSD BP4 250gb (mSATA inside 2.5" enclosure)
  • W11Pro
  • AOC C24G1 + Dell S2415H
  • Cheap CyerPower keyboard (Wooting 60HE coming later this year)
  • Glorious Model O Matte White
  • LTT Northern Lights DeskPad 1000mm x 500mm
  • FX Audio Dac-X6 + Monoprice Modern Retro + Fifine Studio Condenser Mic
Media Server
  • Rosewill RSV-L4412U 12-bay hotswap
  • Unraid 6.9.2
  • Asrock B450 Steel Legend
  • Ryzen 5 3600
  • 2x8gb DDR4
  • LSI 9207-8I
  • 9x 2tb IronWolf • 2x 2tb WD Red • 1x 14tb WD Shucked White Label
  • MSI GTX 1050 Ti
https://linustechtips.com/topic/13232-case-recommendation/#findComment-149673
