I have an asus laptop i78750hq and 1050ti. I play valorant  720p at all low but only MSAA 2x and Anisotropic Filtering 2x. But still not getting 120fps . I use bitsum high perforamce battery mode and fans are set to max. I disable my antivirus while gaming and Nvidia control panel settings are also optimised.CPU temps are 80-90 and gpu is in 80s.  I use throttle stop to undervolt cpu at around -20 mv to reduce cpu temperature.
CPU game time, render time and everything spike when I see an enemy.
https://linustechtips.com/topic/1323125-low-fps-on-games/
looks like cpu bottleneck. can you check if there is a core pinned at 100% in those situations?
https://linustechtips.com/topic/1323125-low-fps-on-games/#findComment-14624087
4 minutes ago, Pavan Yakkali said:
How can we check it?
first ctrl shift esc to open taskmanager, click on performance or something like this, right click on graph to change into logical cores
then click on options - always on top to be sure you can see those statistics even while gaming
https://linustechtips.com/topic/1323125-low-fps-on-games/#findComment-14624222
