Just a quick question that I haven't been able to find a solid answer for.
I bought two sets of these fans https://www.amazon.co.uk/gp/product/B07X8T79QY/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 that comes with 2 controllers. I intend to use 2 controllers and 9 fans leaving one of the controllers with an empty slot.
So my question is can I connect the one controller to the other controller and then only have 1 argb and pwm header connect to my motherboard? Or would each controller need to go to its own argb header and pwm header?
I made this illustration to explain it a bit better.
The motherboard I have purchased has 2 5v argb headers and 2 pwm headers so I can do both controllers on separate headers if necessary.
https://linustechtips.com/topic/1323052-ezdiy-fab-controller-question/
should be fine as long as each controller has its own power.
