So I have an AIO on my cpu already but I'm considering adding more cooling to my rig. Leaving the AIO alone can I just add another radiator to my three front fans and do a loop from that to the water block of my 3080 (when I get to replacing it with a water block) back to the pump? First time considering this so I wanted to see some options from everyone if I can. Will post a pic of the inner workings of the rig (Thanks tempered glass). Thanks in advance!
https://linustechtips.com/topic/1322827-opinion-tank/
If you mean to add more to your current AIO, thats not possible unless AIO was made for it. The point of AIO is that you don't need to open it or do anything but connect and power on.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1322827-opinion-tank/#findComment-14628316
