Origin Pre-built help
Go to solution Solved by Rhinoleader12,
Hello, im looking to purchase a prebuilt from Origin, however, im not too tech savy and may need a little help making sure all of the specs are optimized and are compatible with one another
Any suggestions or advice you can give would be very much appreciated..
Thank you 🙂
Specs:
Variable Mounting : Standard Orientation
Lower Unit : Lower Unit Option
Processors : AMD Ryzen 9 5950X 16-Core 3.4GHz (4.9GHz Max Boost)
Thermal Compound
Motherboard : Gigabyte X570 AORUS Elite WiFi
Memory : 32GB CORSAIR VENGEANCE 3200MHz (2x16GB)
System Cooling : CORSAIR H150i PRO XT RGB Cooler
System Fans : CORSAIR SP120 PRO Performance iCUE RGB controlled by iCUE software
Graphics Cards : NVIDIA 10GB GeForce RTX 3080
Operating System : MS Windows 10 Professional
Hard Drive Cage : 5 Bay Hard-Drive Cage
Operating System Drive : 1TB Samsung 970 EVO Plus NVMe M.2
RAID : No RAID
Hard Drive : 1TB Seagate BarraCuda SSD
Hard Drive : 1
Hard Drive : 2TB ORIGIN PC Approved Hard Drive
Hard Drive : 1
Power Supply : CORSAIR HX1200 PLATINUM
Power Supply Sleeved Cable : No Sleeved Cable
Audio : Integrated High-Definition Audio
Networking : Onboard Network Port
Here is the link for the build:
https://www.originpc.com/configurator/load/3e7243e3-93af-442b-abd7-e71d31d91c0d/
(not concerned about the price)
Thank you 🙂
Specs:
Thermal Compound
RAID : No RAID
Hard Drive : 1
Hard Drive : 1
https://linustechtips.com/topic/1322734-origin-pre-built-help/
Thank you 🙂
Specs:
Thermal Compound
RAID : No RAID
Hard Drive : 1
Hard Drive : 1
Origin is know for having bad value when it comes to prebuilts. You are definitely overpaying for this system, as this would be around a $2500-3000 if you built it yourself. You should probably shop around other prebuilt makers and compare prices.
https://linustechtips.com/topic/1322734-origin-pre-built-help/#findComment-14620253
I checked PC part builder with matching parts and the price turned out higher, for me ive sent like 5k the limit im not gonna go above, price isnt the issue im just concerned the parts may not be compatible/optimized
https://linustechtips.com/topic/1322734-origin-pre-built-help/#findComment-14620259
