Help for selecting PC parts
Solved by curiousmind34,
1 minute ago, Nick123pc said:I want to build a new pc and I need a help to chouse motherboard. Shoud I pick ASUS ROG STRIX Z590-E GAMING WIFI or ASUS TUF Gaming Z590 Plus WIFI. For CPU I pick Intel core i5 11600K.
Both of those motherboards are way overkill, and also you don't have to buy a motherboard with wifi if that is an issue, you can just insert a cheap wifi card into a 1x slot
