Last week I built a pc with
Ryzen 3 2200g
Gigabyte A320M DS2
4GB DDR4 2400mhz
500GB HDD
500w 80+ Bronze PSU
Wraith Prism Cooler
After turning it on the fans were spinning and the RGB are on when we connected the VGA cable to the tv it didn't post or show anything, I tried reseating the ram, CPU and cooler still didn't work. I hope you guys can help me because this is my first ever build and I really need it for online classes and light gaming (planning to upgrade to 16gb ram in the future)
I also heard that AMD will be removing support for VGA I don't know if its true then if it is what should I do, i only have a VGA port on my motherboard and also none of the ports at the back works like the usb my keyboard doesn't even light up or anything
https://linustechtips.com/topic/1322471-my-pc-wont-post/
The motherboard should have come with a motherboard speaker. If you haven’t plugged it in, do so, and power it on again.
it should give you a beep code which will let you know what’s wrong. You can look for the meaning of the beep code in your motherboard’s manual.
If you don’t know about the motherboard speaker, again look in the manual, it should explain everything.
https://linustechtips.com/topic/1322471-my-pc-wont-post/#findComment-14618418
6 minutes ago, Hyrogenes said:
What bios version is it running? You might need to change the bios to support 2nd gen ryzen as it might be currently set to 3rd gen
A320 supports 1st, 2nd, and 3rd gen chips. Also, the 2200G is based on Zen (14nm, Ryzen 1xxx), not Zen+ (12nm, Ryzen 2xxx) since AMD puts the APUs on one generation older of architecture.
PLEASE STOP [Killing] ME I WILL GIVE Y OU ANOTHER DEAL.
https://linustechtips.com/topic/1322471-my-pc-wont-post/#findComment-14618431
it doesn't give any beep sounds what should I do?
https://linustechtips.com/topic/1322471-my-pc-wont-post/#findComment-14618438
Have you checked that you plugged the speaker in the correct way? If you plugged the positive side to the negative slot it won’t work.
(sorry for the redundancy of the questions, it’s just that I’ve made them in the past and they appear quite often😂)
https://linustechtips.com/topic/1322471-my-pc-wont-post/#findComment-14618444
oh wait you mean motherboard speakers sorry, I bought the motherboard used/2nd hand and it didn't came with any speaker so I don't know what to do now
https://linustechtips.com/topic/1322471-my-pc-wont-post/#findComment-14618451
Sorry mate, I don’t know much more to help you, maybe someone else comes with a better solution.
Maybe check if you can get a speaker from someone else, I think all motherboards share the same type of speaker support (better check it though).
https://linustechtips.com/topic/1322471-my-pc-wont-post/#findComment-14618458
its okay thanks for trying 🙂
https://linustechtips.com/topic/1322471-my-pc-wont-post/#findComment-14618465
