I went through all the effort of purchasing all the parts and assembling my pc all on my own, everything works just fine and it detects everything and the pc turned on, however the parts I have are not preforming how they should, it’s preforming absolutely horribly and can’t even play Minecraft, I have a 6 year old 150$ acer work desktop that blows my 1200$ custom build out of the water and I don’t know what to do
(I have a amd Ryzen 5 3600, an msi gtx 1050 Ti, an msi b450 tomahawk max mobo, 16 gigs 2x8 of DDR4 3200 MHz vengeance rgb pro ram, sea gate barracuda 2tb hard drive, and a lian li lancool 2 mesh, white) also for some reason in my task manager my hdd is at 100%
https://linustechtips.com/topic/1321790-somebody-please-help-me/
<-- Moved to Troubleshooting -->
Community Standards
"Beast Mode"
Dedicated Streaming Rig
Do a full scan using Malwarebytes and after that do a full scan using Windows Defender.
This looks like a really obvious virus to me.
hi, im renata bliss and am ur freestyle dance teacher
Well, my money is on the hard drive then. You need to figure out what's tying it up at 100%. It's already slow as molasses on a cold day in January, and if some process is saturating it, then you're not going to be able to do pretty much anything.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
What part of task manager is reporting disk usage at 100%
is is this part?
Click on The 'Disk' column and it will reorder, that might point to the offending process.
Also, don't have your boot (Windows) drive on a mechanical disk, always use an SSD. Even an old 2.5" sata drive would do but use an NVMe if you can.
Living Room PC - Lian-Li O11 XL Evo - MSI X870 Tomahawk Mobo - AMD 9800X3D - 32GB DDR5 Ram - RTX 4090 - 2TB Samsung 990Pro NVMe - Antec 1200w PSU - Dual Custom Loop Cooling - GPU cooled with EK Quantum Surface S240 + EK Quantum Surface P360M X-Flow Rads - CPU cooled with EK Quantum Surface X360M Rad
Bedroom PC - Hyte Y60 - Intel Core i5 13600k - MSI Pro-A Wifi Z790 Mobo DDR5 - 32GB Ram - RTX 5070ti - 1TB Samsung 990Pro NVMe - Corsair HX1200i PSU - CPU + GPU cooled with Hyte Y60 Corner Distro Plate - EK Coolstream S120 + EK Quantum Surface S360 + EK Quantum Surface X240M
Extension PC - Lian Li o11 Dynamic - Intel Core i9 9900k - MSI Meg Ace Z390 Mobo - 16GB Ram - RTX 3080ti - 256GB Samsung NVMe - Corsair AX850 PSU - CPU + GPU cooled with dual EKWB 360 Rads + G1 side EKWB distro plate.
Office PC - Thermaltake Tower 100 - Intel Core i7 8086K - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - iGPU - 256GB Samsung NVMe - EVGA B5 850W PSU - CPU cooled with dual EK Quantum Surface P120M Rads + Barrow 3-in-1 Block, Res & Pump.
Spare - Corsair 250D - Intel Core i7 8700k - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - GTX 980ti - 256GB Samsung NVMe - BeQuiet P11 750 PSU - CPU cooled with EK Coolstream S240 + S120 Rads + EK Pump / Res Combo
Annex - Corsair 280X - Intel Core i7 4790k - Asrock H97M ITX Mobo  - 16GB Ram - EVGA GTX 1080ti - Corsair SFXL600 PSU - CPU + GPU cooled with triple EK Coolstream S240s + EK Pump / Res Combo
NAS PC - Fractal Node 804 - Intel Core i7 3770k - Asus P8Z77-M Mobo - 16GB Ram - MSI GTX 1660 Ventus - Corsair AX850 PSU - Unraid 21TB Storage Server
Living Room AV Setup 5.1.4 - Nvidia Shield - Yamaha RX-A6A - 2 x B&W CM9s2 - 2 x Monitor Audio FX Silvers - 4 x B&W CCM665s - B&W CMCs2 - SVS SB13 Ultra - LG OLED65C1
Extension AV Setup - Sonos ARC + Sub (Gen 3) - LG OLED65C6V + Sonos Amp - 5 x Monitor Audio C265s
Bedroom AV Setup - Yamaha WXC-50 - 2 x B&W CM1s - Rel Quake - LG OLED42C2.
Have you installed the manufacturers drivers for the motherboard (chipset drivers), have you enabled the Ryzen power plans, have you installed the Nvidia GPU drivers?
Try disabling the Windows search indexer to see if that lightens the disk load.
