Help with ESD/Grounding.
Go to solution Solved by tikker,
16 minutes ago, DannyBoii said:
Yeah I do. I just don't have money to replace anything if I shock it to death xD The table is plastic and wood. I am paranoid!
EDIT: As long as my power strip has a ground/is plugged into a grounded outlet my esd strap is grounded, right?
Ah ok, so you didn't mean literally taking components out on carpet. Yes a grounded plug in a grounded power strip in a grounded outlet should be grounded. An ESD strap isn't so much about absolute ground really. It's to put you on the same potential as what you are working with.
 I've got a plastic mat on my medium pile carpet. My apartment only has carpet, but I have an esd bracelet. am I good if I ground on a plugged in/turned off PSU?
I have to take parts out of a pc on the carpet and put some of them in my new build. I feel like I should take the psu from my old pc and then ground via the esd bracelet and I should be good. Is that accurate?
https://linustechtips.com/topic/1321438-help-with-esdgrounding/
Should be. For actual ground ground the socket it's plugged into will also need to be grounded of course.
Do you not have a table or something?
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
https://linustechtips.com/topic/1321438-help-with-esdgrounding/#findComment-14610114
https://linustechtips.com/topic/1321438-help-with-esdgrounding/#findComment-14610117
https://linustechtips.com/topic/1321438-help-with-esdgrounding/#findComment-14610149
Know any relevant tutorials I should read?
https://linustechtips.com/topic/1321438-help-with-esdgrounding/#findComment-14610153
It's really hard to kill compontes with esd.
It's still hard if you are trying to (see ltt vid)
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
https://linustechtips.com/topic/1321438-help-with-esdgrounding/#findComment-14610160
