I want to add watercooling to my build, a costum loop, I currently have h100i but I want to change that out and stuff, I have an i7-4770k @4.3 Ghz atm might higher it, and asus 780 OC.....
What pump radiator and stuff should I have, I'd pref as quiet as possible, any suggestions is a huge help, thanks!
I've got nzxt 630 case.
Emmh... Maybe consider killing yourself before you talk to me?
Pople on this forum though some of them had a brain, turns out, no.
https://linustechtips.com/topic/132077-help-with-watercooling/
case? that really what we need to know to help you
ITX Monster: CPU: I5 4690K GPU: MSI 970 4G Mobo: Asus Formula VI Impact RAM: Kingston 8 GB 1600MHz PSU: Corsair RM 650 SSD: Crucial MX100 512 GB HDD: laptop drive 1TB Keyboard: logitech G710+ Mouse: Steelseries Rival Monitor: LG IPS 23" Case: Corsair 250D Cooling: H100i
Mobile: Phone: Broken HTC One (M7) Totaly Broken OnePlus ONE Samsung S6 32GB  :wub:  Tablet: Google Nexus 7 2013 edition
https://linustechtips.com/topic/132077-help-with-watercooling/#findComment-1757574
If you're a first time watercooler, please read this thread. http://linustechtips.com/main/topic/1755-water-cooling-101-a-good-place-for-newbies-to-start/
Also, what's your budget?
I like the color scheme of Noctua fans. Deal with it. Forget about the bad memories of the past.
"wunder you really are as straight as a rainbow" - Lanoi "can I fisterino your nose" - WunderWuffle
Forget about the bad memories of the past, take the good ones along with you through the present, and look forwards to the good things that will come in the future.
https://linustechtips.com/topic/132077-help-with-watercooling/#findComment-1757731
$200-250 I'd prefer, need more help, thanks guys!
https://linustechtips.com/topic/132077-help-with-watercooling/#findComment-1763350
@Ghost made a budget watercooling thread a while back, but I forgot the link. If you want, you can also get a Swiftech H220 or a Coolermaster Glacer 240L and expand the cooler.
https://linustechtips.com/topic/132077-help-with-watercooling/#findComment-1763438
It's in the FAQ Under Section 2.8.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/132077-help-with-watercooling/#findComment-1763626
As mentioned go for a D5, and rads, IMO, Alphacool all the way. The rest comes down to personal taste, do you want a bay res, double or single, ir do you want a tube res, 150mm or 250mm ( and more ) Do you want a res pump combo or seperate units, the list goes on mate.
MSI Z87 XPower, I5 4670k, 4x4gb Avexir MPower, 2 x HD7950, XFX Pro750w, Intel 335 180gb boot, 250gb Samy pro games, 60gb OCZ Vertex music, Monsta 420,ST30 360, 140mm / 120mm Akasa Vipers in push pull, D5 Vario, Koolance top, Bitspower ZMulti250, Fesser Fittings all round, Mayhems sunset Yellow, 32" LG monitor, 23" Asus monitor, Microlab Solo 7c's, Bheringer MS20's, R.A.T7, Steelseries Merc Stealth
https://linustechtips.com/topic/132077-help-with-watercooling/#findComment-1764071
