3 minutes ago, Jin Erishon said:
Budget (including currency):
Country:
Games, programs or workloads that it will be used for:
We dont know what you want from this, I know you just joined today so its OK. Can you tell us what your current specs are and what you want to upgrade, as well as what your budget is please
Big nerd.
 PCPartPicker List Link
Ryzen 5 1400, Deepcool Gammaxx 400 V2 Blue, Biostar B450MH, Timetec 2x8GB 3200MHz CL16, Adata SU650 240GB, WD Blue 250GB 7200RPM, Seagate Barracuda 320GB 7200RPM, MSI Aero GTX 1060 3GB, Cougar MG130G, Segotep 750W Fully Modular 80+ Gold, HP 22EB, Samsung S22E450D, Sceptre E205-W, Gamakay LK67 with Gat Reds and HK Gaming Chalk keycaps, Logitech G305 Lightspeed, Shure MV7, Gertisan Mic Arm, OneOdio Headphones, CM SickleFlow Blue Fan, Iceberg Thermal IceGALE 140MM Teal x2, Cougar case fan
Rack Project (Build log link)
https://linustechtips.com/topic/1320714-updating-parts/#findComment-14604315
46 minutes ago, Jin Erishon said:
Fujitsu Lifebook ah556
With laptops you can usually upgrade ram and storage. Depending on what ram and storage you have now and what you're doing with the laptop, this may or may not be a good investment. So we need a bit more detail. What ram do you have? What storage? What do you do with the laptop? What do you want it to do that it's not doing now?
https://linustechtips.com/topic/1320714-updating-parts/#findComment-14604424
