So today I got arma 3 from a friend and I am having some major issues. I am getting very low fps 20-30 fps on ultra high and low. I don't see how it is possible that I am getting the same fps at ultra and in Low. When I run the game I notice that only 4 out of 8 cores are actually running the game and those 4 cores are only at half usage. I have the FX-8350 and the GIgabyte 7970 ghz . Is there any fix for this issue?
[CPU] i7 4790K OC [CPU Cooler] H100i [GPU] Evga GTX 980 SuperClocked [Ram] Corsair Vengeance 16 GB 1866 mhz [PSU] Cooler Master 1000w Silent Pro [storage] 256 GB Samsung 840 Pro, 1TB Seagate SSHD, 1 TB WD Blue 4 TB Seagate Nas. [Motherboard] Msi Z97 Gaming 5 [Case] Phantom 410 Red [sound] Onboard ALC 1150 [Headphones] Sennheiser HD 558 [Keyboard] Razer BlackWidow Chroma  [Mouse] Razer Deathadder Chroma [Mouse] Razer FireFly [Monitor] Asus MG278Q
https://linustechtips.com/topic/132059-arma-3-issue/
So you mean that a top of the line amd CPU can't run Arma 3 at 30+ fps even on lowest settings? @kuzimins
https://linustechtips.com/topic/132059-arma-3-issue/#findComment-1757556
Arma 3 depends on single core, and because amd is bad at that stuff (they have more but less powerful cores) and intel rocks (more powerful cores but less of them).
Its just a badly optimized game. Your fps actually isnt that bad for that game.
I don't always have time to study, but when I do, I don't.
https://linustechtips.com/topic/132059-arma-3-issue/#findComment-1757634
If that is not bad than what is the average fps that people should be getting in this game? @kuzimins
https://linustechtips.com/topic/132059-arma-3-issue/#findComment-1758677
ARMA 3 runs fine on AMD CPUs. I have an FX 6350 overclocked to 5GHz and I run 60fps in singleplayer. Multiplayer however, runs like crap on every type of cpu, it is entirely dependent upon the server and your internet connection.
[AMD Athlon 64 Mobile 4000+ Socket 754 | Gigabyte GA-K8NS Pro nForce3 | OCZ 2GB DDR PC3200 | Sapphire HD 3850 512MB AGP | 850 Evo | Seasonic 430W | Win XP/10]
https://linustechtips.com/topic/132059-arma-3-issue/#findComment-1758684
Your explanation seems to be a little off.
https://linustechtips.com/topic/132059-arma-3-issue/#findComment-1758700
fixed
Falcon: Corsair 750D 8320at4.6ghz 1.3v | 4GB MSI Gaming R9-290 @1000/1250 | 2x8GB 2400mhz Kingston HyperX Beast | Asus ROG Crosshair V Formula | Antec H620 | Corsair RM750w | Crucial M500 240GB, Toshiba 2TB, DarkThemeMasterRace, my G3258 has an upgrade path, my fx8320 doesn't need one...total cost £840=cpu£105, board£65, ram£105, Cooler £20, GPU£200, PSU£88, SSD£75, HDD£57, case£125.
 CASE:-NZXT S340 Black, CPU:-FX8120 @4.2Ghz, COOLER:-CM Hyper 212 EVO, BOARD:-MSI 970 Gaming, RAM:-2x4gb 2400mhz Corsair Vengeance Pro, GPU: SLI EVGA GTX480's @700/1000, PSU:-Corsair CX600m, HDD:-WD green 160GB+2TB toshiba
CASE:-(probably) Cooltek U1, CPU:-G3258 @4.5ghx, COOLER:-stock(soon "MSI Dragon" AiO likely), BOARD:-MSI z87i ITX Gaming, RAM:-1x4gb 1333mhz Patriot, GPU: Asus DCU2 r9-270 OC@1000/1500mem, PSU:-Sweex 350w.., HDD:-WD Caviar Blue 640GB
CASE:-TBD, CPU:-Core2Quad QX9650 @4Ghz, COOLER:-OCZ 92mm tower thing, BOARD:-MSI p43-c51, RAM:-4x1GB 800mhz Corsair XMS2, GPU: Zotac GTX460se @800/1000, PSU:-OCZ600sxs, HDD:-WD green 160GBBlueJean-A
 CASE:-Black/Blue Sharkoon T9, CPU:-Phenom2 x4 B55 @3.6Ghz/1.4v, COOLER:-FX8320 Stock HSF, BOARD:-M5A78L-M/USB3, RAM:-4GB 1333mhz Kingston low profile at 1600mhz, GPU:-EVGA GTX285, PSU:-Antec TP550w modu, STORAGE:-240gb  M500+2TB Toshiba
CASE:-icute zl02-3g-bb, CPU:-Phenom2 X6 1055t @3.5Ghz, COOLER:-Stock, BOARD:-Asrock m3a UCC, RAM:2x2GB 1333mhz Zeppelin (thats yellow!), GPU: XFX 1GB HD6870xxx, PSU:-some 450 POS, HDD:-WD Scorpio blue 120GB
CASE:-Packard Bell iMedia X2424, Custom black/red Aerocool Xpredator fulltower, CPU's:-E5200, C2D [email protected]<script cf-hash='f9e31' type="text/javascript"> /* */</script>(so e8500), COOLER:-Scythe Big shuriken2 Rev B, BFG gtx260 sp216 OC, RAM:-tons..
Gigabyte GTX460, Gigabyte gt430,
GPU's:-GT210 1GB,  asus hd6670 1GB gddr5, XFX XXX 9600gt 512mb Alpha dog edition, few q6600's
PICTURES CASE:-CIT mars black+red, CPU:-Athlon K6 650mhz slot A, COOLER:-Stock, BOARD:-QDI Kinetiz 7a, RAM:-256+256+256MB 133mhz SDram, GPU:-inno3d geforce4 mx440 64mb, PSU:-E-Zcool 450w, STORAGE:-2x WD 40gb "black" drives,
CASE:-silver/red raidmax cobra, CPU:-Athlon64 4000+, COOLER:-BIG stock one, BOARD:-MSI something*, RAM:-(matched pair)2x1GB 400mhz ECC transcend, GPU:-ati 9800se@375core/325mem, PSU:-pfft, HDD:-2x maxtor 80gb,
PICTURES CASE:-silver/red raidmax cobra (another), CPU:-Pentium4 2.8ghz prescott, COOLER:-Artic Coolering Freezer4, BOARD:-DFI lanparty infinity 865 R2, RAM:-(matched pair)2x1GB 400mhz kingston, GPU:-ati 9550@375core/325mem, PSU:-pfft, HDD:-another 2x WD 80gb,
CASE:-ML110 G4, CPU:-xeon 4030, COOLER:-stock leaf blower, BOARD:-stock raid 771 board, RAM:-2x2GB 666mhz kingston ECC ddr2, GPU:-9400GT 1GB, PSU:-stock delta, RAID:-JMicron JMB363 card+onboard raid controller, HDD:-320gb hitachi OS, 2xMaxtor 160gb raid1, 500gb samsungSP, 160gb WD, LAPTOP:-Dell n5030, CPU:-replaced s*** cel900 with awesome C2D E8100, RAM:-2x2GB 1333mhz ddr3, HDD:-320gb, PHONE's:-LG optimus 3D (p920) on 2.3.5@300-600mhz de-clock (batteryFTW)
https://linustechtips.com/topic/132059-arma-3-issue/#findComment-1759090
what others are saying is likely to be bull.
while i havent benchmarked it yet at 1080p with my sig rig i get around 45 (or so) fps on the top sceneraio where you walk through the valley with everything maxed out.
it evenly uses 4 cores so its not cpu limited, to be sure i would go into windows task manager and assign cores 2+3, 4_5, 6+7 to run arma 3, or if that still doesnt work just try the latter 4 cores (2 modules)
a piledriver core is more powerful than a phenom core and from experiance ive noticed no benefit to cpu overclocking as yet.
what I have noticed as many other have is that arma 3 is a pig to run on equal footing it seems as crysis 3. (going by web reviews)
if you like do a 180sec fraps runthrough on a given setting on the "valley" scenario (where a guy gets shot you have to assault a town and then find the spotters) start the fraps run from where matey gets hit,
monitor cpu and gpu usage in task manager and msi afterburner and post back here.
https://linustechtips.com/topic/132059-arma-3-issue/#findComment-1759096
ARMA 3 runs fine on AMD CPUs. I have an FX 6350 overclocked to 5GHz and I run 60fps in singleplayer. Multiplayer however, runs crap on every type of copu, it is entirely dependent upon the server and your internet connection.
Off Topic: What cooler and voltage do you use in your overclock? I'm using stock cooler and stock voltage and the max 'stable' overclock I can achieve is 4.19~4.2GHz. (I'm quite a noob at overclocking).
On topic: I have similar issues with Arma 3. I get 40-60fps on single player (however it is jumpy), however, on muliplayer, I would be impressed to hold a steady 30 frames. I average 15 fps on most multiplayer servers.
Wishing leads to ambition and ambition leads to motivation and motivation leads to me building an illegal rocket ship in my backyard.
https://linustechtips.com/topic/132059-arma-3-issue/#findComment-1759121
arma3 3ghz phenom x4 7850
3ghz
arma3 4ghz phenom x4 7850
4ghz
4ghz 7850 ultra 1080p
Frames, Time (ms), Min, Max, Avg
  3237,    108810,  21,  37, 29.749
fraps
3ghz 7850 ultra 1080p
  4810,    180000,  20,  34, 26.722
get way higher if i just use very high settings, ultra kills it.
maybe do the usually driver checks (typical go-to answer) but see what benefits you can from module asigning although its most likely a game issue, most games i come across seem to be limited by the game engine/api before my cpu or card even (especially) simcity.
edit: just run it on high (or very high, second one from top) at 2.5ghz and the gpu hovers around 80% and the cpu around 65% and i get around 28(min)-40fps, very playable, bit gutted it doesnt fully use the gpu though.
https://linustechtips.com/topic/132059-arma-3-issue/#findComment-1759238
I use an NZXT Kraken X60 with 1.47v for my cpu overclock.
I have difficulty maintaining 15 fps in most multiplayer servers. There are qualitry servers that allow me 30fps or more, but it's usually the Altis life servers that run like crap
https://linustechtips.com/topic/132059-arma-3-issue/#findComment-1760205
Sure m8, now go and play some multiplayer servers with >40 players, and get 45 fps. It just wont happen.
https://linustechtips.com/topic/132059-arma-3-issue/#findComment-1761668
did OP mention multiplayer? wheres your PS?
https://linustechtips.com/topic/132059-arma-3-issue/#findComment-1764189
