My computer when starting up loops and never gets a chance to get to the windows 10 load up. I tried 3 different ssd and hdd so I know it's not that plus a boot media to see if I can do a reset. No matter what I can't get to the windows 10 screen, as soon as it finishes with the msi logo it restarts the computer and starts over. It's not the ram as I switch them out and only used one. So it could only come down to the psu, mobo, or the cpu. My question is if it was the mobo would it even start? The psu doesn't seem likely as it doesn't have an issues looping but I could be wrong. The cpu could be likely but I just don't know. Has anyone else had this problem and could lend any info? By the way this started one day when I was in the middle of watching a video on my computer and it  just randomly restarted and since then it has been in this state.
Cpu: AMD Ryzen 9 3950X
Psu: Corsair - RMx Series 850W 80 Plus Gold
Mobo: MSI Meg Unify x570
Video: https://imgur.com/iF2HYef
Edit: Should of mentioned this in the original post. I cleared the CMOS. Also I reset the bios to default. I also upgraded and downgraded my bios with different versions through mflash and still had the same problem.
https://linustechtips.com/topic/1319917-loop-boot-problem/
Have you cleared CMOS on the motherboard? Instructions should be on page 44 of the manual
Main PC:
AMD Ryzen 7 5800X • Noctua NH-D15 • MSI MAG B550 Tomahawk • 2x8GB G.skill Trident Z Neo 3600MHz CL16 • MSI VENTUS 3X GeForce RTX 3070 OC • Samsung 970 Evo 1TB • Samsung 860 Evo 1TB • Cosair iCUE 465X RGB • Corsair RMx 750W (White)
Peripherals/Other:
ASUS VG27AQ • G PRO K/DA • G502 Hero K/DA • G733 K/DA • G840 K/DA • Oculus Quest 2 • Nintendo Switch (Rev. 2)
Laptop (Dell XPS 13):
Intel Core i7-1195G7 • Intel Iris Xe Graphics • 16GB LPDDR4x 4267MHz • 512GB M.2 PCIe NVMe SSD • 13.4" OLED 3.5K InfinityEdge Display (3456x2160, 400nit, touch).
Got any questions about my system or peripherals? Feel free to tag me (@bellabichon) and I'll be happy to give you my two cents.
PSA: Posting a PCPartPicker list with no explanation isn't helpful for first-time builders :)
https://linustechtips.com/topic/1319917-loop-boot-problem/#findComment-14597736
Yes I cleared the CMOS. Also I reset the bios to default. I also upgraded and downgraded my bios with different versions through mflash and still had the same problem.
https://linustechtips.com/topic/1319917-loop-boot-problem/#findComment-14597821
