I have the ASUS ROG Crosshair VIII Dark Hero X570 and the antenna that is included is very long, not magnetic, and no matter where I put it on my case it is either tilted or doesn't say on the top.
Can someone recommend me a antenna replacement that will preform the same performance and/or range? I think I should get this but I don't know if there are better options that I can't find.
https://linustechtips.com/topic/1319869-i-need-help-finding-a/
I would use ethernet but tryhttps://www.amazon.com/Techkey-1750Mbps-1300Mbps-Antennas-Wireless/dp/B07PKMFPF7/ref=sr_1_8?crid=IH0CP22BMETD&dchild=1&keywords=usb+3.0+wifi+adapter&qid=1616965633&sprefix=USB+3.0+wifi%2Caps%2C178&sr=8-8
https://linustechtips.com/topic/1319869-i-need-help-finding-a/#findComment-14597333
32 minutes ago, Dk SPYder said:
I think they were just looking for antennas, not with usb. Even if they were to get a seperate soundcard, I would reccomend pcie.
https://linustechtips.com/topic/1319869-i-need-help-finding-a/#findComment-14597390
To be able to get best range and wireless reception, antennae like this one have an advantage over the one you linked to because their position can be manipulated independently from the computer's position.
https://linustechtips.com/topic/1319869-i-need-help-finding-a/#findComment-14597405
On 3/28/2021 at 5:07 PM, Dk SPYder said:
I am going to use ethernet but I also want bluetooth connectivity.
I saw that but the reason why I didn't pick that is because I want to use the existing antenna screw things on the motherboard.
Sorry for taking so long to respond, for some reason the message was saved as a draft instead of the message being sent.
https://linustechtips.com/topic/1319869-i-need-help-finding-a/#findComment-14600255
