Just finished updating/upgrading my pc.
fitted motherboard and cooler and sp120 fans by Corsair in my new case the Corsair 220t icue case
rocking a i9 10900 on a MSI b460 tomahawk motherboard (no overclocking so don’t need a z490/z590 boosts) with 32GB ram clocked at 3000mhz with a RTX 2080. Only the one ssd m.2 512gb saberent I think. Fans are controlled using the Corsair commander pro with an rgb controller.
Just thought I’d share my rig with you as of inspiration for other to maybe go off.
Happy Easter Holidays, p.s I know I’m a week off but what the heck 😁
i5 3570k 3.4GHZ, 8GB HyperX 1866mhz, GTX 960, ADATA 120GB SSD, 500GB HDD, Logitech G402, AFX Ultimate Gaming Keyboard
https://linustechtips.com/topic/1319626-my-finished-build/
looks clean and tidy, i guess the specs in your signature are from your old PC.
I am with you about the CPU, put the money into a better non K CPU and no need to overclock. i am now running a i9 9900 and apparently the difference to a 9900K (at stock speeds for gaming is 1%) so its a no brainer, why have something that will just produce more heat, use more electric when there is nothing wrong with a non K CPU.
https://linustechtips.com/topic/1319626-my-finished-build/#findComment-14597501
