Hi all, I'm trying to identify this graphics card. I know its a GTX 770 2GB, but can't figure out the brand or confirm model number etc. The closest GPU seems to be the PNY XLR8 GTX 770 Enthusiast Edition - VCGGTX7702XPB https://www.techpowerup.com/gpu-specs/pny-xlr8-gtx-770-enthusiast-edition.b1957
It just seems odd that my one doesn't have any stickers/PNY labelling and doesn't have Nvidia on the PCB by the 16x connector.
I'm asking as I'm looking to sell it but I bought it used and don't have any info on it - checked the listing and it basically said Geforce GTX 770, nothing else.
Any help identifying it would be appreciated,
Mark
https://linustechtips.com/topic/1319316-help-identifying-graphics-card/
Are you able to install it and then use GPU-Z might give you more information on the graphics card if the actual unit itself is hard to identify [You might find out brand then and some other info]
Ryzen 9 7950X 5.9 GHz 16-Core, Full Liquid CoolingROG Crosshair X670E EXTREMEG.Skill Trident Z5 6000 MHz 64 GB, EVGA GeForce RTX 3080 Ti FTW3 Ultra 12 GBSeasonic PRIME Platinum 1000WKingston HyperX Cloud II 7.1 Channel, S.S Arctis 5 7.1Roccat Kain 200 AIMOLogitech G403 HeroASUS TUF VG27WQ 1440P 165 HzASUS VG34VQL1B 34" 1440P Ultrawide 165 HzCrucial P1 1 TB M.2-2280 NVME 2xSamsung 870 QVO 4 TB 2.5" SSDFractal Design Meshify 2 XL Case
It might be an OEM card.
The PN (part number) on the back points to ZOTAC and PC Partner, but neither seem to be exactly perfect matches nor do they have official product pages or reviews attached to them.
Maybe it came out of a pre-assembled brand? like Alienware or something dunno i been scouring the web for numbers and other information and cannot find anything about it it does resemble the PNY mentioned the most but it has no of the frontal markers at all and the back of the PCB looks different.
Thanks all for the replies, I hadn’t considered whether it had come out of a prebuilt, that could make some sense with a bulk load of CPU’s from an oem. The PNY and Zotac options is what I found too but like you say it is only mentioned on a couple of pages in the whole of the web so it seems very rare/not mentioned, sold individually etc. I did try and identify it in Nvidia control panel, user benchmark and a couple of other ways and it just states Nvidia GeForce GTX 770 etc, I’ll give GPU-Z a go.
Thanks again,
Mark
