So a few days ago was totally fine but now I am seeing high memory issues.
With just discord, 3 tabs on chrome and teams opened I am seeing 70-80% ram usage which in not normal.
When I play a game, for example valorant ram usage is 95-97% while CPU and GPU sits around at 50-60% and loading screens are 2-3 minutes long (on an ssd).
After a 5-10 minute session of valorant the paged pool was 1.5 gigs.
Specs (laptop):
ryzen 5 3550H
8gbs ram
gtx 1660 ti max-q
https://linustechtips.com/topic/1319265-higher-than-usual-memory-usage/
5 minutes ago, ShungShan said:
8gbs ram
you can check the memory utilization in task manager.
7 minutes ago, Benji said:
I assume he knows how to do that already 😉
I had a similar experience running 1809 on my laptop and it upgrading to 1909, that caused a high RAM load, even during idle when nothing was running. What fixed it for me was either upgrading to 20H2 or factory resetting. I never really found another solution for it, it just apparently does that on occasion.
I'm already on 20H2, but I guess I will just reinstall windows to see if that fixes it.
