First time building pc help (case)
Go to solution Solved by Downkey,
Just now, DrAGoni_Penguin said:
, is there no holes or openings? not even a honeycomb shaped grid?
yes, no real room for airflow and no cutouts. Just a solid front pannel. There are mesh cases that can be found in this pricepoint, so i see no reason too get this
Budget (including currency): hopefully <50 but if needed <60
Country: USA
Games, programs or workloads that it will be used for: Pretty much everything, but minecraft with high settings, lots of browsing and streaming, recording, and zoom (zoom is terrible on my current device. 2009 stuff honestly)
Other details I plan to pair a RX 470 with a ryzen 5 3600 and get the wraith spire cooler separately if needed. (i believe it's cheaper to get the 3600 and get the cooler instead of getting the 3600x.
I found a MSI TOMAHAWK MAX II motherboard, which seems to have the compatibility I'm looking for.
I'm getting TEAMGROUP 16gb 8gb x 2 3200MHz C16 RAM and thats about all I have right now.
I do not want to get anything rgb or at least disable it. I'm looking for a pc case.
Thanks!
-someone who isn't experienced and is completely new to this.
ps: if someone can post a list of everything a pc needs, that would be great!
I'm looking to compile a list of everything the build could have in case prices fall eventually.
https://linustechtips.com/topic/1318479-first-time-building-pc-help-case/
i found https://amzn.to/2PoatbU
but I dunno how to see if it will fit everything needed and have room for extra fans.
I basically just don't know if the gpu and cpu will fit honestly.
that has no airflow. Don't get that
geometry is hard
b550 > x570
geometry is hard
b550 > x570
