Hello,
Yesterday when I was playing, my monitor went black then showed No signal message and turned off, gpu led was on, the fans were at 100% even after few restarts and about 15 minutes of idling.
I then plugged in my hdmi into motherboard and it worked fine, I opened hardware id, and there's only integrated graphics showing, no rx 480. I then used ddu and uninstalled amd drivers and plugged hdmi into gpu, and it didn't work, I then went back to integrated graphics and tried to install amd drivers, but as I was installing them popped up an error with no amd gpu found. Is the gpu dead, or are there anything that can fix it?
https://linustechtips.com/topic/1318389-help-rx-480-died/
19 minutes ago, Justinas said:
Hello,
Same happened to me some time ago, i took it to a repair shop and they said it probably was the memory and its un economical to repair and that i should get a new one. Try ur luck with taking it to a gpu repair place and they might fix it up because the gpu prices are insane these days.
https://linustechtips.com/topic/1318389-help-rx-480-died/#findComment-14585839
Try reseating it first before coming to conclusions.
https://linustechtips.com/topic/1318389-help-rx-480-died/#findComment-14585872
