Help trying to physically build computer
Go to solution Solved by Tea1337,
Use the instructions that came with the cooler, it is probably the most accurate.
I'm having alot of problem creating this Havik 120 cooler and installing the motherboard cables...
My havik 120 has metal clips instead of rubber clips, so the guide on youtube is pretty different.
I have intel cpu so I'm having issues copying the youtube clip that uses AMD mounting.
Is there anyway I can add someone on skype to help me on this?
https://linustechtips.com/topic/131837-help-trying-to-physically-build-computer/
